Old 02-21-2008, 12:29 AM   #18
Benny986
Originally Posted by Gary in BR
My current spring rates are 300 front and 500 rear.
I know these are very stiff, my original thought is to just go with softer springs. Most spring rates for the 986 are 200-300 range. The reason I am considering just going to a Bilsten-H&R setup is I will only have to do the work once.
DO you guys think softening the springs will help with the "porpoising" I am getting?
thats actually kinda of soft, and the range is interesting. i'm not too family with boxster spring setup, but is the 200lb difference front to rear normal?
i have 400s up front and 550 in the back. i also have a dual spring setup, so its actually a bit higher than that.
i also have higher canister pressures up front than out back. by about 100lbs i think.
my ride is very comfy.
are you on 19s? go back to 18s if so. what is your exact setup now? and describe how the car rides.
and by porpoising. do you mean that under acell, the front end seems to lift up? if so, i think our cars just do that.
Benny986 is offline   Reply With Quote
