Old 02-17-2005, 04:28 PM   #17
donv
donv's Avatar
Glad you figured out the glue on the sides. I just used an X-Acto knife on it at the time, no way I was going to get the Dremel in there...
How did you retain the harness in the channel at the back of the storage compartment? If you did the hot melt glue instead of the clips from the kit, I suggest you rethink that. I know my procedure suggested the hot melt - but I later found out the heat in the summer back there was enough to melt the glue! It then wicks into the engine cover carpeting... not what was intended.
I've meant to update that information posted, but haven't got around to it yet...
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
