Old 02-16-2008, 03:43 PM   #1
bmussatti
Guest
Posts: n/a
Well, here are a couple things to consider:
1) It will take about 200 miles for the tires to "scrub" in.
2) You are using non Porsche approved tires, so you should also expect less than optimum performance.
3) What is the air temp there now?
4) Check you tire pressures. Tire shops usually over inflate tires. You might get better grip with tire pressure adjustments.
