I finally got some time, and checked the front radiators today. They are completely clean, there is nothing wrong with them. Which, from what I have read narrows it down to three things the engine fan fuse, right/left radiator fan fuse, or the coolant.
I checked the coolant and it is about 1" below the minimum mark, which is bad. According to the guy I talked to at the Porsche dealer, if the coolant level is low the engine could be heating up more than the gauge is showing. Is that true?
Also, should I just add coolant, or should I flush it?
Thanks!
