Old 02-10-2008, 02:15 PM   #18
fatmike
Originally Posted by yjm3
Which leads to my next question -
Are there any options you guys could not live without in the boxster? Also, anyone have a hardtop?
Thanks,
Vince
In your original post, you said you were considering an '02 thru '05 "S". There is difference between '02 vs. '03/'04. And a very big difference between the '02-'04 and the '05. Porsche changed the model designation in '05 to the "987" model. Prior to that, the Boxster was a "986" model. You can search this forum for the differences.
I consider Stability Control and Litronics (Xenon Headlights) to be the two must-have options.
The '03 model brought a glass rear window and an engine tweak. The glass rear window is certainly a nice-to-have and something you'll get if you buy on the newer side of your range.
But, if you can afford a 987 it is generally considered a step-up.
Good luck in your search.
SOLD - 2002 Boxster S - PSM, Litronics, De-ambered, Bird Bike Rack, Hardtop, RMS leak...
fatmike is offline   Reply With Quote
