Originally Posted by pompous
That may be the case, but I also went w/the 275/40/18 on the rear and regret it. I wish I would have gotten 275/35/18 instead, b/c each time I hit a bump w/much speed at all it makes this horrendous rubbing noise. I've been told its pretty easy to fix it, but never got to it and now I can't remember how.
You'd have the same problem with a 35 aspect ratio tire if you're rubbing on the fender.
You've either got to change your offset (and make sure you're not touching any suspension components) or roll the fender, as Kirk says.
