Old 02-06-2008, 07:30 PM   #12
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by blueillusion97
I recently installed the same new design shifter...After reading numerous comments that its not reversible i just didn't believe it and got it anyway....sure enough it is reversible...Newer shifter does not have nuts on both sides of the shaft like the previous one, instead is has threads in the housing it self and one nut on the other side...so what you need to do it undo the nut so that the tread is showing of the bolt then grab the bolt just hard enough not to shave off the thread and twist it and it will unscrew...then the bolt just simply comes out, reverse the shaft, screw the bolt back in, screw the nut back on and you are done...
Just to make it clear you bought your shifter recently from a2rinc correct?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
