Old 02-03-2008, 09:18 PM   #9
Lil bastard
Lil bastard's Avatar
Good advice, check under the Trunk floor. If none is found, and if it were me, I'd pull the Oil Dipstick (assuming you have one) and make sure you're not running a cappucino emusion because coolant is passing by one of your head gaskets and mixing with the engine oil. Absent a Dipstick, I'd drain the Oil and look for the tell-tale signs of a headgasket leak, then dump the Oil back in if it's not time for a change. The coolant has to be going somewhere and a leaky headgasket can cause all sort of internal engine damage to bearings, cams, etc.
