Looks good. Hope you red locktite'd the threadcert or it may pull out if you ever remove the caliper bolt in the future. @ 85Nm (63 ft.-lb.) to tighten/loosen the Caliper bolt (you'll undoubtedly apply more when removing if you use a breaker bar), you also want the threadcert to stay fast.
