Old 02-01-2008, 12:56 PM   #10
porsche986spyder
Originally Posted by steve00s
I do not believe your CEL's are caused by the removal of the secondary cats. Those are downstream from the sensors and should not result in CEL's. The deloboz header has only one O2 bung per header (positioned towards the rear of the header), if I am not mistaken, and this is probably what is causing the problem. You could try having another bung welded towards the front. Maxspeed sells headers on Ebay and you can see from the pictures where the placement of the bungs are (they have two bungs per header). You can also puchase an extender piece that screws into the bung (put in the second bung) and pulls the sensor back out of the airflow slightly. These sell for about $20.
Yep, that's really the only way to go unless you buy some expensive High-flow Cats that are built into the headers, like the Fabspeed ones or leave the cats on the down pipes only and delete the first set in the headers, but you can't delete all 4 without getting the cell light to coming on. Unless you relocate or weld on the extra bung wholes. Sound kind of tricky.
porsche986spyder is offline   Reply With Quote
