Hey, when I went home for lunch, I jumped started the car using the bolt that holds the negative cable to the chassis, (had not read blue2000s's post until now)
My logic was that this is clearly a bolt attached to the frame so it seems safe to me as previous post suggested finding a bolt to attach the negative clamp to.....
It started right up, drove it to run some errands and back to work, probably a good 50 minutes total. Hopefully I won't be stuck in the parking lot after work.
blue2000's post "Don't use the bolt that holds the negative cable to the chassis, it's right next to the battery"
