Old 01-29-2008, 08:18 PM   #1
gstoli
Originally Posted by Jay Nichols
Here is what I used.
http://www.superbrightleds.com/mini-wedge.html
Haven't done the rest of the interior light yet, they have the small wedge for the instruments panel lights and the one for window switch and headlight control switches, but don't know the exact one to order yet.
Jay
Thanks for the list. For the window switches you need two smd PLCC-2 leds for each one and needs ironing (you have to remove the old ambers and iron the new). For the headlight switch you need the simple 3mm leds (again ironing to remove the old ones and to install the new). The worse part is that you can't remove the headlight switch from the car so you will need to iron in the car... Be carfull with the hot thing when you are in your lovely Box
After you do all that you would want to change the AC and radio leds, and eventually you will become a professional electrician (I know I have )
Good luck
George
gstoli is offline   Reply With Quote
