Your lights could work, and you still may have a bad battery. When was it last changed? If you are on your original one, it is definitely due for a change, and if you changed one 4 years ago, then I'd still check the battery. This seems to come up all the time, but basically there is much less draw on the battery from the various components than from trying to start the car.
Good luck.
