I used the Mintex semi-metallic...works great with little dust and good braking but I think any other brand like Pagid, Hawk, PBR etc would be fine. My Mintex pads came with the drilled holes and it was easy to replace in 45 minutes or so if you have done it before. Dealer typically would replace rotors and change pads for $700-1000 from what I heard. I don't really know why they charge so much for such a simple job. Oh, you may also want to buy the brake shims cause the old shims are stuck like glue to the old pads.
