Originally Posted by Bob O
Based on your criteria, you should go with oem. You can pick them up lots of places on the net for less than the dealer charges. Change them yourself and go drive it. If you want less brake dust, then some others are better. If you want better grip, some others are better. You apparently don't desire either, so.. go with oem. The factory pads are very good, just very dusty. You might want to do some research in the archives here or on several other boards to get an idea of what other people say about various pads. Neither Mintex or Hawk would reduce your braking ability. Both offer at least equal grip to the oem pads.
Bob
Better grip would be a plus, but I don't want to throw off current brake bias, since I will keep the rear OEM pads. In addition, I want a pad that works well cold and does not require a lot of warming up. The pads I have been looking at were either the Hawk HPS, Axxis Deluxe and obviously OEM.
Are there any others you guys feel I should consider?
Thanks again
