Old 01-23-2008, 03:56 PM   #1
ut_cougar
Largest Wheels possible?
Hi, i'm new the forum and looked around but can't find an answer to a simple question. I have a 2002 Boxster S and am looking to buy new wheels. Does anyone know the largest size wheels i can fit on the boxster without any rubbing or other fitting problems? I would like to go as big as possible (BUT want to be able to easily take the wheels on and off without having any other complex install problems). I read on here about spacers, etc which I don't know much about so maybe someone can explain if spacers are a good or bad thing? I would like to put 19's or 20's IF they fit. I would like to go as TALL as possible and as WIDE as possible so if anyone can give me the measurements that are the maximum I would appreciate it. The car currently is totally stock and I will not be lowering the ride height, etc. Also any info on the tires that will be needed to go along with the new large wheels would be a big help (lower profile needed i assume?)Thanks for any info guys, its apprecaited.
ut_cougar is offline   Reply With Quote
