Old 01-21-2008, 08:03 PM   #10
Acid_J
should I run the same tire pressures as on a dry day or lower? I would assume since cornering speeds will be lower that you can run lower tire pressures (less tire roll to worry about). I generally try to run 40 hot (start at 34ish cold) on a dry track.
Jason
'99 AS Boxster
Acid_J is offline   Reply With Quote
