Originally Posted by boxs2000
Have you thought about having your alignment adjusted (more camber) to keep the rear from rubbing. I would try that first because I had my fenders rolled before on my GTI and it worked but it also made the lip weaker because the edge that was put on it for strength was rolled in and it warped after awhile.
I already rolled my fenders, I did that last night. But yeah you're spot on - if the fender rolling didn't give me enough clearance, then I'll get it aligned for more negative camber in the rear.
Kirk
