Originally Posted by efahl
More data is always good, do you have a way to datalog the EGT and lambda along with some other engine parameters (RPM, throttle position and that sort of thing)? Analyzing logs is so much easier than trying to look at gauges while you're driving (but then, if you make a video of all the gauges, you can do a fair amount of "log analysis" that way).
Eric
Thanks for exhaustive reply. I just wrote Gary quite the missive (post here) on my O2/egt/boost etc plans. Give it a read if you can stay awake through it. Like to respond to your notes but I gotta sleep.I'll Give it the twice over it deserves ASAP.
Thanks much
PK
