Fits 987 and Cayman Too!
Just some more info regarding the fit of the lower stress bars on the 987 and Cayman.
The guys at Niello Porsche in Sacramento, CA were very kind today and let me and my assistant crawl under their new 987's and Caymans, including the new 987 special edition and the Cayman S by Porsche Design. We were getting measurements and checking the fit on parts. Here's what I found:
A few things have changed from the 986, but the key dimensions between the mounting points for the bars has not changed. In fact the 987 and Cayman dimensions are exactly the same as my 986. The only things that I've seen different are:
1. The newer cars have a coating on the Porsche stress plate that the stress bars reinforce.
2. The newer 6 speed transmission gives a lot more room for installation.
3. The suspension point where the main bar mounts is a bit different, but dimensionally still the same.
4. The side braces are different, but still have the same kind of tab that needs to be removed to install the side braces. I took some photos for the instructions.
That's about it. I even tried fitting some side bars in place to see if there was enough room and there were no problems.
So spread the word. If you've got a 987 Boxster/Boxster S or a Cayman/Cayman S these lower stress bars will definitely fit.
Here's a photo of my assistant hard at work doing some measurements and test fitting.
Kirk
Reason: Fixed mispeeled wurd
