Old 01-17-2008, 02:59 PM   #16
porsche986spyder
Originally Posted by Bob Z.
A lot of folks are running 7mm spacers on the front and 15mm on the rear. Excuse my ignorance but if the rear tires are wider, why would one use larger spacers on the rear vice the front? My objective is to bring the wheels/tires closer to the wheel well lip after I lower it with H&R springs.
Simple, people do that to keep the STAGGERED fitment. You can still achieve that with the same size spacers all the way around as long as your rims are still wider in the rear than they are in the front.
So as long as you don't try to put bigger ones in the front than the rear to make them even out, you shouldn't have any problems keeping your car with a staggered fitment.
porsche986spyder is offline   Reply With Quote
