Old 01-17-2008, 10:06 AM   #3
Kirk
A spoiler that big will have to be bolted to the rear trunk. When you get the spoiler it should come with a template to show you where to drill the holes. You would then drill holes in the rear trunk and bolt up into the spoiler from inside the trunk lid. You'll need to use a rubber gasket or some sealant to keep the holes from leaking water into your trunk. I've only seen the very smallest wings that mount with double-sided tape. For anything as big as this that's just not practical.
When searching for this wing (it's technically a wing, not a spoiler), don't forget Gemballa. They make a version of this wing that is almost an exact copy. Heinz Meis with Gemballa NA can probably get you one, but it would be much more expensive than the eBay source.
Kirk
Kirk is offline   Reply With Quote
