Old 01-17-2008, 12:31 AM   #2
markabanksy
Airbag Deactivaction Bar / Buckle
Not sure if people realise but I have found that I did not need to manufacture a male clip to slot in the buckle of an airbag deactivation bar to deactivate the airbag. There is a more simple solution.
It appears that the switch in the female buckle does not carry an electrical current across the male clip. It is simply a switch that is on or off dependent on the clip being inserted or removed.
To deactivate the airbag I simply inseted a match stick or small screw driver into the buckle, press down, hear the click and the buckle thinks the clip is inserted. When I want to reset the airbag back on, I simply repeat the process.
The airbag (on my car anyway) light flashes as it should and then goes out. Works fine and I got a better fitting child seat that the Porsche one for £50.
markabanksy is offline   Reply With Quote
