Old 01-15-2008, 06:09 PM   #3
schwank
I had everything apart today... it is not that tough. I do prefer the wheel studs on my 944's as they make it way easier to mount the wheel again. And it is definitely a pain to jack that thing and get it on stands. I really really need a lift.
Only problem? Performance products shipped me Zimmerman drilled rotors that fit a regular Boxster, not the S-specific models. I even called them when I got them asking about the vaning and they said it's OK they are internally non-directional. Well, after I got in there and compared the rotors, the front ones they sent me are definitely not correct.
SO... I did not end up doing anything as I did not want to install new pads on the old rotors, which are VERY worn, knowing I would then have to rebed when the new rotors come. I basically took everything apart for fun, and put it back together again.
I have the correct rotors on the way, but I can't return the ones I have because I painted the hats. Anyone want a deal on drilled rotors for the BASE Boxster, with nicely painted black rotor hats?
life is participation in evolution
87 944 PRO44 racer. 01 986S (race build in progress), 93 968
schwank is offline   Reply With Quote
