Originally Posted by Frodo
"hey is that the same car in both pics of the sig? the grays look very different..."
Posted by super66.
I've found pics of the seal grey can look a lot different, color-wise, from one time to the next depending on the light. (Maybe more so than some other colors.) Look---in a close up shot I made mine look blue! (No computer-adjustment on the color.)
I've found that my slate grey metallic looks a lot different depending on the light - and some of issue with a digital camera is the white balance. To get true colors you need to use some method of manual white balance with digital camera. Not to get into all the details of this (although I would be glad to elaborate if necessary) and depending on what camera you have usually you shoot a separate photo of a white piece of paper - or if you're into photography, an 18 percent gray card - which is getting the same light as your car (that is, don't have the white paper in the shade and car in the sun or vice-versa) and use that to calibrate your manual white balance. Colors will be very close using that method. However, unless your monitor is color calibrated it still won't look right on your monitor (but nothing else will either). I still haven't shot any photos of my car with manual white balance set in the camera. There are also ways to arrive at a fairly accurate white balance after the fact using Photoshop or the image processing software that came with your camera. In this case it helps to have something in the shot that is known to be pure white or pure gray to sample the color from.
