Old 01-09-2008, 01:21 PM   #14
Padawan
Originally Posted by porsche986spyder
I found the easiest and simplest way to get the correct reading NO MATTER WHAT MODEL BOXSTER you have is to fill your tank up with the key turned to the far right, the "ON" position that will display your readings. Of course do not turn the car on so the engine starts. Simply fill your tank up and you can watch the gas gauge fill while you sit in your car. You will never get a false reading this way and it will "FILL UP" to the full mark on the tank reading this way.
You're mistakenly assuming that the fuel sending unit is functioning correctly, which it doesn't seem to be in certain cases, hence the TSB discussed in this thread. Incidentally, mine must have somehow freed itself (temporarily, at least) and finally registered a full tank at my last few fill-ups. I never thought I'd be so pleased to simply have a fuel gauge that works.
2000 Guards Red Boxster
There is no substitute.
Padawan is offline   Reply With Quote
