Originally Posted by trunkmonkey
I have this problem too but in my case the gas tank is not actually full and the pump is just auto-shutoff. I found this info about it:
http://www.986faq.com/10-0/problems.asp#018
Mine is a 987 2007, the dealer says they can't reproduce the problem so they wont fix it. anyone have this issue with a 987?
I found the easiest and simplest way to get the correct reading NO MATTER WHAT MODEL BOXSTER you have is to fill your tank up with the key turned to the far right, the "ON" position that will display your readings. Of course do not turn the car on so the engine starts. Simply fill your tank up and you can watch the gas gauge fill while you sit in your car. You will never get a false reading this way and it will "FILL UP" to the full mark on the tank reading this way.
