Old 01-08-2008, 08:53 AM   #11
Bsignor
Send a message via AIM to Bsignor
Methanol Injection
pinzgo,
I have used methanol injection on several Mustang Cobras in the past; the injector should be placed after the supercharger (boost side). How much boost are you running, are your EGT’S high or you looking for a power adder.
I would not recommend doing an aggressive Tune with methanol. If the system fails for any reason so goes the motor. Meth is a great cooling agent when running high boost (12psi +). Its protects your motor from detonation if you get bad gas. A 50/50 mix with meth & distilled water is a great mix. I hope this helps.
Bsignor is offline   Reply With Quote
