Old 01-07-2008, 10:39 AM   #1
boxster6354
boxster6354's Avatar
Clutch Issue when fan is on
Hello All -
Situation:
While releasing the clutch pedal in 1st gear from a stop I am getting a little bit of a jerk, somewhere between the feel of when you started to learn to drive a stick and a failing clutch.
But this only happens when I have either the A/C or heater on with Fan and car is cold, after it warms up 180+ I do not have the issue. Tried while car was cold and fan turned off and clutch feel is great.
I seldom run the car with the top up or the A/C or heater on, but the other day it was a little chilly with top down and I had turned on the heater to warm the toes a bit when I discovered it.
Also when I say cold I am only talking in the 60's
Car;
2000 986 base
45k mileage
boxster6354 is offline   Reply With Quote
