Old 01-04-2008, 09:19 AM   #2
OldBlevins
The key in the lock won't turn, or it turns and the console remains locked? Any chance it's overloaded and the pressure is keeping the lock from turning? If you haven't already, you might try pushing down on the console top while turning the key.
Just in case your key isn't engaging the cylinder properly, you might also try squirting a little WD-40 or similar lubricant in the keyhole.
- Jim
2000 Boxster S, Speed Yellow, Michelin AS/3 tires, 60,000 miles...
... and climbing.
OldBlevins is offline   Reply With Quote
