Old 12-30-2007, 06:16 PM   #3
cas951
Originally Posted by Paul
Usually warped rotors, sometimes contamination on the rotors, sometimes loose tie rod ends.
+1 Warped rotors.
Normally when you put in new pads rotor should either be resurfaced or replaced. This way the brake pad and rotor surface is flat and have equal contact on all areas. One thing to try is to break in the pad to the rotor. This is done by hard braking about 10-15 times from 50-0 mph. Do this several times and the pad will wear into the rotor surface.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
