Old 12-29-2007, 09:24 PM   #32
Uncle Bob
I started using it in the late 60's when first building motorcycle engines. Always used a high temp lead or copper based paste. I also use it on my wheels. It's saved having the wheels bond to the hubs (alum alloy to steel). Never had a problem with it. Yes, a little goes a long way. I was taught to spread it evenly in the threads and wipe excess prior to threading.
We use it in the refinery business as a matter of course. You try removing a 2 1/8" nut that's been heat cycled to over 800F several hundred times without it....it's no different in cryogenic service. Lots of our refrigerated propane systems run at -60F and anti seize is a must.
I've read the TSB's also and take them with a grain of salt.
To each his own indeed!
"The car you've dreamed of owning is the same one our designers and engineers dreamed of building."
Peter Schwarzenbauer
My car @ Car Domain
http://img.photobucket.com/albums/v2...nstalled01.jpghttp://img.photobucket.com/albums/v2...nstalled02.jpg
Arctic Silver '05 Silver Boxster
Uncle Bob is offline   Reply With Quote
