			RMS is not the biggest expense you can have in a Boxster or Carrera but there is no gurantee that replacing the seal will fix the leak. You could end up with another RMS leak a short while later. The shaft could be out of center in a big way and throwing another seal at it is just a band aid solution. I would pass on this Boxster unless they offered you a substantial reduction, at least $4-5K or a extended factory warranty on the drive train.
BORN: March 2000 - FINLAND
