Thread: Car won't start
Old 12-27-2007, 12:50 AM   #2
pk2
Try this...
Originally Posted by HB.
Today was raining pretty moderate when I left out. I... open one of the doors the rear trunk lid opens, and you can hear this slight buzzing sound coming from the rear of the car.
Has anyone dealt with this before, what could be wrong, and how much does this problem cost to fix?
Sounds like a problem I had; water leak, it all winds up under the drivers’ seat where the security computer (black box) thing is located (brilliant). You can find out really quick if you reach down & back under the seat, feel around and see if it’s wet.
If it is, take the seat out ASAP and yank out the box (easy). Open it up, if there’s moisture in it, dry it out well, scrub off any signs of corrosion (white mold like) with a soft wire brush, then dust it with WD or contact cleaner.
Put it back together and in. Make sure the cable contacts are clean of any corrosion and well seated. If you caught it soon enough & your lucky it will work. It happened to 3 times while I looked for the leak (still can’t find it). I finally wised up and drilled a couple holes in the floor.
Regards, PK
P.S. If this is the problem, leaks can originate from plugged drain holes to the rt. & lft. of the motor
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
