Old 02-04-2005, 10:31 AM   #1
jwocky
It can mean a whole slew of things. If it's blinking, definitely do not drive the car anymore (as this is an indication of something majorly wrong). If you know anyone with an OBD-II reader they can pull the fault code for you and then you can just ask around here or search around for Porsche OBD fault codes to see exactly what the problem is. Or, I've heard that places like Jiffy Lube or Autozone will read the fault code for you. Either way, the manual won't tell you what's wrong because the CEL can be lit for tons of reasons. Good luck!
- Jason
jwocky is offline   Reply With Quote
