Old 12-20-2007, 09:55 AM   #10
porsche986spyder
[QUOTE=Kirk]Right, the link you gave is for the Upsolute remap, which I think is really the only comparable, lower cost option out there, which I mentioned in my first post.
I was just saying it didn't seem like much BANG FOR THE BUCK. $900. for 18hp! I knew there were others out there cheaper. Upsolute you mentioned is cheaper by $200.00 over the Softech option. Softech doesn't sound very easy to install with all of the warnings it mentions while doing the install yourself while plugged in on-line!!? By the way, Unichip, like I said only makes a System that works with the "S" type which is the 3.2Ltr. Not the 2.7Ltr. So I'm not sure where that chart you posted came from. They use a biggy-back type of system the plugs into the O.B.D. and allows you to turn it on or off when needed. That was what I liked about it. Not sure about what they used to sell for your WRX. Maybe they have changed since then. Other than that, the cost was worth the HP & TRQ. But like I said, unless you have a 3.2 it does matter anyway.
porsche986spyder is offline   Reply With Quote
