The color of the box/packaging is not important as long as you get the semi-metallic ones for street application. I think the old packaging came in red box. Hence, everyone called it the "red box mintex". EBC and other main brands are good too. There is no need to replace the wear sensor unless your brake light sensor has come on. You may also want to get new shims but you can use the old ones if you like but again you may have to superglue the old shims to the new pads and use a mallet to flatten the old shims.
