Originally Posted by Gary in BR
Hello,
I can not seem to find the hack that allows the Boxster to be started with out depressing the clutch pedal, does anyone have the link to this hack.
Gary
I don't know the link to the hack, but all you need to do is look under the dash, push in the clutch pedal and you will see the little switch that is pushed in when depressed. All you need to do is find a big enough tie wrap and zip it around the switch to keep it in the same position as it would be if you are pressing down the pedal and thats it. Its a 30 second hack.
