Originally Posted by RandallNeighbour
I think the 3.4 has different headers than the 2.5 ...
Yes, but when you put the 3.4 motor into the boxster, I believe it goes it "backwards", and then you would use a boxster header, so you could get an aftermarket header now for the 2.5/2.7/3.2 and then use it on the 3.4 later as well.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
