Old 12-13-2007, 11:42 AM   #11
mtch
Originally Posted by maxferran
Once again, I am not worried about the tow rating. The v6 caynne base has the same tow capacity as the v8 s, the turbo, and the turbo s. I am not going far and not getting enough speed pull myself off the road.
You should be!!! You will ruin an expensive vehicle is you repeatedly tow over a vehicle's capacity.
You cannot tell me a turbo s with more power than an h1 hummer cannot pull an 8k lb boat up a gentle boat ramp slope.
Power is not the determining factor. A turbo s need RPMs to spool the turbo which generates its power and torque to move the load. The high RPM and a slow moving vehicle = new tranny.
The H 1 makes no power, but LOADS of TQ off throttle. Plus it has torque multiplying hubs and a super low granny gear, so can tow a small village with stressing it's tranny or other hardware.
If my range rover that weighed 4401 with a 7700 lb tow capacity could handle it with ease, the 4950 lbs cayenne with the same tow capacity can do the same. Thats enough tow talk.
There are many factors that go into tow ratings, and you should research the topic more thoroughly before spending serious $$. Based on your comments it seems that your understanding in not complete.
mtch is offline   Reply With Quote
