Old 02-01-2005, 10:57 PM   #3
Cold Warrior
I like the idea of re-forming the plastic...
Originally Posted by jfmillr
I would be careful. I have 18" rims that are 9" wide in front and 10" wide in back. The fronts cant support wider then 225's without a slight rub. I would be careful going any wider or else you will need to modify the wheel wells.(cut the plastic or melt it and reshape it to allow for turning radius) As for the back I have 275's and still wouldnt suggest going any wider. I have the Bilstein coilover shocks and spring and it is as low as the H&R springs. If you go too wide on the tires you will rub the edge of the wheel well.
as it seems to be the only interference point with these particular wheels/offsets. I had a set of 225-40 18 MPSC's mounted on 8.5" et 50mm Fikse FM-5s (same dimensions as my new Volk TE37's) that bolted right up to the front hubs with no spacers and the only thing that seemed to come close was the plastic wheel well cover. There seemed to be room to grow with regards to the fender lip.
Thanks for the reply,
CW
"Lotta people go through life doing things badly.
Racing's important to men who do it well.
When you're racing, it's life.
Anything that happens before or after is just waiting."
-M. Delaney (Steve McQueen, "Le Mans")
Cold Warrior is offline   Reply With Quote
