Chris: This is directly from my dealer 45k service invoice: (personally I believe many of these items are skipped by many dealers, such as my dealer did not find the small parking light was out on the ltronics on one side).
oil change
check air filter, replace if needed
read out fault codes
visual inspection underside and engine compartment for leaks chafing wires and hoses check underbody paneling securely fastened
check power sterring fluid level
check coolant hose condition, check for debris and blockage of radiators and air inlets
check coolant level and antifreeze protection level
replace pollen filter
check brake hoses and lines for signs of damage, corrosion and correct routing
check brake fluid level
check drive shaft boots for leaks and signs of damage
check tire condition and pressure
check firewall and cabrio section body drains for debris
check for adjustment and functioning properly, door locks, lid locks and safety hook of front lid
check inner release of front luggage compartment on 2002+ (2003+ boxster)
check operation of vehicle lights
check headlight alignment
check horn operation
windshield washer, headlight washer check fluid level, nozzle settings, and antifreeze protection level
check operation of all other elctrical equipment and indicator and warning lights
also during road or dyno test:
remote control, front seats, foot brake, parking brake, engine, clutch, steering, transmission park assist, cruise control, TC/pwm switches, heate, AC, check operation
Oils, fluids, visual inspection for leaks
Also airbag check and brake fluid change are on a cycle (I think 4 years for airbag and 2 for brake fluid I need to check). So depending on when those were done last they may do those too (probably at extra cost)
They also added one bottle of fule injector cleaner to the gas tank
