Old 12-09-2007, 09:11 AM   #1
Tool Pants
A long time ago someone had the same problem. Turned out both low beam bulbs burned out at the same time - believe it or not.
So I would rule out that you have 2 burned out low beam bulbs. The high and low beam bulbs are the same. So swap your low beam bulbs with the hight beam bulbs and see what happens.
Tool Pants is offline   Reply With Quote
