Old 12-09-2007, 08:57 AM   #3
saaber
Originally Posted by FrayAdjacent
I think the part you are thinking about is actually on the top itself. It clips into the little retainers on the cable ends and has a U shaped plastic piece. This part would cause water runoff to go to either side into the foam channels on either side, to the drains on either side.
What you're seeing in that picture is all you should see (minus the engine insulation/carpeted pad).
Ah, that makes sense now. Thanks very much.
We had a major deluge 2 weeks ago and the car was parked on an incline with the front of the car facing uphill. I guess those two factors are what caused the problem because I have never seen it leak before. I will keep and eye on it and waterproof the top also as I haven't done that for quite a while.
Thanks again. Also FYI my reseach on the internet and elsewhere found that the best way to kill mildew before it gets started is white vinegar. I was able to dry this spill out right away but used vinegar just in case...
saaber is offline   Reply With Quote
