Old 12-08-2007, 08:50 PM   #2
rick3000
There Is No Substitute.
rick3000's Avatar
It could be a problem with a wire between the switch/fuses and the actual headlights. You could try checking in the front trunk, near the wiring harness (by the battery) then follow the wires to the headlights to check for corrosion or just a problem with one of the wires.
