Thread: short shift kit
Old 12-07-2007, 09:51 AM   #23
Tool Pants
The clone I bought had a sloppy fitting bushing, and you can see how bad because I measured the bushings and the journals. It has to be a guality control issue because the other bushing was ok.
As I said in the link, when I install a B&M I first check the fit of the bushings. So, I did the same with the clone out of habit. I doubt many people check the fit of the bushings, so maybe I was the first to notice it, or I just got an oddball bushing.
I would not want to put in any shift that may end up rocking a bit due to a poorly fitted bushing. Other than that, the clone is well made. It does the same thing as a B&M and you can't beat the price.
Tool Pants is offline   Reply With Quote
