Thread: short shift kit
Old 12-07-2007, 05:59 AM   #22
dmenn
Send a message via AIM to dmenn
Blink - you confirmed exactly what I'm saying. The differences between two of the same knock-off SSKs should not be significant, but they are. If you are creating SSKs in a quality controlled environment with the proper equipment, you will see very small variations from one to the next. The example on renntech clearly shows that these cheap SSKs are not quality controlled.
So when I said you get what you pay for you'll probably get something that will fit, but not necessarily perfect and not up the standards of what they should be, that's all.
Originally Posted by blinkwatt
None of the cheap ebay ones come with the lube either. Remember, you get what you pay for.
Just use lithium grease. $.02 worth of grease shouldn't be a factor when buying a short shift kit.
I'd also check out renntech.org if you're thinking about one of these knockoffs - there is a nice thread on the cheap ebay models. The bushings aren't the same size and while it may seem to fit right, it doesn't.
I'm starting to think Toolpants got a bad ssk. Many of us haven't had an issue with out kits from a2rinc. My 1st one I installed was snug and fit how it should have been,not loose like his bad bushing was on his kit. I'm installing two more this evening and will check for any play or obvious difference in the bushings.
2000 Boxster S, Arctic Silver, Natural Grey Leather
Factory: Aerokit I, 18" Sport Classics, Xenons, Heated Seats, Premium Sound, and more..
Upgrades: Bumper Plugs, Door Plug, Clear Sides, Clear Tails, Clear Bulbs, Painted Bumperettes, 997 Shifter, EVO Intake
dmenn is offline   Reply With Quote
