Thread: short shift kit
Old 12-06-2007, 08:38 AM   #21
blinkwatt
Send a message via AIM to blinkwatt
None of the cheap ebay ones come with the lube either. Remember, you get what you pay for.
Just use lithium grease. $.02 worth of grease shouldn't be a factor when buying a short shift kit.
I'd also check out renntech.org if you're thinking about one of these knockoffs - there is a nice thread on the cheap ebay models. The bushings aren't the same size and while it may seem to fit right, it doesn't.
I'm starting to think Toolpants got a bad ssk. Many of us haven't had an issue with out kits from a2rinc. My 1st one I installed was snug and fit how it should have been,not loose like his bad bushing was on his kit. I'm installing two more this evening and will check for any play or obvious difference in the bushings.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
