Thread: Replacing Amp
Old 12-04-2007, 03:10 AM   #5
Burg Boxster
Originally Posted by dcompress
I have a 1998 with the 590 radio option (dash and door speakers) with the CDR-210. I purchased a rear speaker set from PNP. I wanted to wire it directly into the amp, so I found a 6x40 factory amp on ebay out of a 911. In this a plug and play type of replacement? I have the additional cable and wiring instructions for the rear speakers.
I am also thinking of trying to find a CDR-220 to keep the factory look, but add the ability to plug the ipod in directly. Has anyone done this, or do you just go with an aftermarket? If I go aftermarket, can I use the existing amp and wiring?
Thanks!
6x40W amp transplant is plug n play - you just need to trim 2 tabs off the inside of the new amp to accept the harness on your 986. Also, you need to use the 4 empty pins on your existing harness (5/15/6/16) not the ones in Harvey's instructions (he'll confirm that for you as well - the ones in his instr. are for '03-'04MY)
Enjoy!
