Old 12-02-2007, 05:40 AM   #2
Burg Boxster
.01 is the correct revision though others have rec'd a .02 (newer revision) out there.
Regarding flashing light/coolant levels, it is a pressurized system. Did you bleed it correctly after reinstalling the new tank to get the air out? If not, do bleed it at once. Afterwards, make sure your fluid is topped off and you put the bleeder valve back down to the closed position.
If you again loose fluid, you'll want to have a pressure test done on the system to ensure you don't have a bad hose somewhere else or, heaven forbid though it's been known to happen, your new tank might be cracked too
